12 gauge wire to speaker from amp??
hey guys.. i installed my amp last weekend.. and im waiting on my box witht the 2 kickers.. my friend was reading the manual that came with the amp while i was installing.. and said that it called for 12 ga. wire to be run as ur speaker wire from ur amp to ur subs??!??!.. why so big.. and why cant i just run 18 ga.?
It would depend on the amount of power that you have running threw the wire but the larger it is the more power you can run threw it with the least lose of power or heat buildup. Ultimatly it will sound a little better using the proper guage wire. I have 1 kicker L7 w/ a 400watt kicker amp and I used a 12guage to the sub. I think that if the box you have is a kicker box you will beable to get 8g, maybe 4g in there.
omg.. well.. no the box and subs i got off ebay as a package.. theres a thread somewhere in here about it.. has the link too.. but anyways.. the amp is about 300 rms.. i have some extra 10ga layin around.. u think i should jsut use that if i can fit it?
No harm in running thicker wires, go as high as you can. Also keep in mind the distance between the amp and sup, shorter could get away with smaller wire but I'd want bigger to carry more power much easier.
well my amp is litteraly.. less than 2 foot of wire away..
but im a little confused.. can i just use the 10 gauge power/ground type of wire as the speaker wire?.. or is it a diff type of wire? bc also.. im not sure that the 10 gauge will fit in the little slot that the box has.. for the sub connection
If it will fit 12 gauge it will most likely fit 10 as well. I have some 12 gauge that looks more like 16 IMO so be careful what the actual gauge is, they tend to exaggerate and some companies even include the insulation.
Two feet away go with 12 unless you have extra 10 that will fit in the amp, like I said bigger can't hurt, if it fits use it.
ya.. the only problem i think i might have is connecting to the push in terminals on the box.. the amp i think i will be fine.. but still am not sure if i can just use power/ground cable.. is it all the same?.. or does it have to be "SPEAKER" wire..
ya its the cvrs.. 10's.. is his 400 watt amp.. max 400 or rms?
i htink im just gunna do it right and go pick up some 12 ga speaker wire.. ive done everythign else the rite way, and made sure of it.. it would be stupid to slack off on such an easy thing.. so ill just pick some up...
thanks tho.
thanks tho.
