bazooka el8a with no wire
Old Jan 29, 2007 | 12:38 AM
thenewbreed's Avatar
HI
I am trying to install a bazooka el8a with powered amp to my phase linear head unit. it has sub outs, but i do not have any wires for the sub. I have an 06 f150. Can I connect the FAST connector to the truck and then to the wiring harness for the bazooka tube, or do I run the bazooka tube harness directly thru the wiring with my stereo.
Old Jan 29, 2007 | 07:26 PM
Bartak1's Avatar
I really dont know a thing about those Bazooka tubes, but I will try to help.
After a little searching I see that the tube accepts line level or speaker level inputs for signal. Since your head unit has sub outs, I would run a pair of RCA's from the HU to the Bazooka's RCA inputs.
Im not sure what the fast connector is. I found this on the Bazooka website...
http://www.bazooka.com/productAutoAm...sEL.asp?id=102
Is that what your needing?
With that you would be able to plug that into your amp, then run your RCA's to it, a power wire, ground wire, and turn on wire.
Im guessing all those other wires are speaker level inputs...
Sorry I cant help more, like I said Im just not familiar with Bazooka. I looked in the manual on the Bazooka website and it was pretty much useless...
Old Mar 8, 2007 | 09:46 PM
thanks for the help. I actually found a connection that plugs into the tube andd you connect the rca's pre amp wore and red and black
