Speaker Problem
Old Dec 22, 2006 | 07:36 PM
Stangler's Avatar
Speaker Problem
I have a 97 supercab that I just got. The previous owner told me that he unplugged the speaker in the rear door for whatever reason. How would I get in to it to plug it back in. Thanks
Old Dec 29, 2006 | 03:38 PM
oLdSchL's Avatar
take off the door panel and reconnect the (+) and (-) wires
Old Dec 29, 2006 | 06:11 PM
Bartak1's Avatar
Great answer there^...yep....
To get the the speaker in the door, you will need to:
1. Take out the two phillips screws that hold the window latch to the door.
2. The whole plastic trim piece that goes around the window is held on with clips...I grab onto the very top of mine and give it a good tug, it should pull straight off.
3. Now you will see at the top of the bottom panel, there is a nut, two of those 'center push' clip things, and a screw. They all need to come off/out.
If youve never seen one of those clips, you have to push the center part in a little bit, then you can get a fingernail under the whole clip and pull it out. When you put it back in, you have to first push the center so it stick out from the rest of the clip, stick it in the hole, then push the center it.
4. Lift up on the panel and then away from the door.
There are 4 little bolts that hold the speaker in.
Old Dec 29, 2006 | 06:17 PM
oLdSchL's Avatar
Even better answer there^...yep....lol jp
