Sweetie..does this make me look fat??? - Speakers
Old Nov 14, 2006 | 12:59 PM
alex_pitts87's Avatar
http://cgi.ebay.com/ebaymotors/INFIN...QQcmdZViewItem
what do i gotta do to get these in to my truck. i mean with the wires making it all come together...
Old Nov 14, 2006 | 01:18 PM
bushtree's Avatar
Nothing.. They will fit right in the door. All you need to do is splice the new speakers to the factory speaker wires already in the door..
Old Nov 14, 2006 | 02:51 PM
azmidget91's Avatar
yep they will go right in and you can splice into the factory wires but i would recommend getting cheaper speakers if that is what you are gonna do, cuz those will sound just the same as cheaper ones if you dont amp them, i would really recommend you get an amp for those speakers, if you need help i could give you a hand installing them
Old Nov 14, 2006 | 04:36 PM
02SuperCrew4X's Avatar
Should fit perfect but WTF is up with that title?
Old Nov 14, 2006 | 05:08 PM
bushtree's Avatar
I could help you with installation as well.. Only problem is it would cost me a bit to get up to you.. (im in tucson)
Old Nov 14, 2006 | 06:19 PM
haha the title is just a good way to get people to read the tread...
but thanks i can handle the install i was just seeing if there was anything in perticular i should look out for.
Old Nov 14, 2006 | 08:54 PM
Bartak1's Avatar
Id amp them too-and not use the factory wiring.
New wire from the amp to the crossover, then from the crossover to the mids/tweets.
Old Nov 14, 2006 | 08:59 PM
ian51279's Avatar
They will fit. You'll have to enlarge the hole for the tweeter a little bit. The crossovers will fit under the switch panels. My speaker grilles won't go back on though. I lack only a little bit, so 1 day I'm gonna cut the grille off the tweeter. What kind of HU are you running? I replaced my factory with a JVC I had laying around out of the last truck. Not the HU I want, but better than the factory HU.
If you have done basic car stereo stuff before you can do these.
