help?!
Old Nov 12, 2006 | 08:44 PM
BLACKBEAST02's Avatar
help?!
i have for rockford fosgate p2 tens under my back seat hooked up to a 2400 watt mono power akustic amp and i keep having problems. the piece where the amp wire connects to the sub snapped of of one and now another one isnt hitting. what should i do?? change amps?change subs?
Old Nov 12, 2006 | 08:54 PM
Bartak1's Avatar
What?
Old Nov 12, 2006 | 09:02 PM
if the terminal on the box itself is broken, you can just replace that cup. If its the terminal on the sub, you might be able to repair it.
-Patrick
Old Nov 12, 2006 | 11:28 PM
ok so im sick of rockford fosgate. iva had two defective subs alread and havent had the system for 4 months yet. thinkin about the infinty perfect kappa? any other sugestions? and should i run two amps to for subs or is just one fine
Old Nov 13, 2006 | 12:40 AM
Depends on the power your one amp runs versus two amps. When set up properly it shouldnt matter how many amps you have as long as the power is there.
-Patrick
