Wire in Series or Parallel?
Old Nov 9, 2006 | 10:01 AM
SSpiro's Avatar
Differences in the two? Is it just the ohmage?
Old Nov 9, 2006 | 10:12 AM
styxnpicks's Avatar
depends on what your amp is stable at
Old Nov 9, 2006 | 10:23 AM
SSpiro's Avatar
Figures. I can't find the specs online now.
Zapco AG 700.
Old Nov 9, 2006 | 11:36 AM
brypink2's Avatar
Zapco AG 700.
You mean AG 750. It is stable to 2 ohm stereo 4 ohm mono.
Go here for your manual:
http://www.zapco.com/
Click on products, scroll down to heritage and click on your amp.
Old Nov 9, 2006 | 12:18 PM
SSpiro's Avatar
Yes, that one. I make that mistake all the time.
According to JL, series is 4ohm... so I need to wire in series (2 subs) into the mono (bridged) output, correct?
Old Nov 9, 2006 | 12:19 PM
brypink2's Avatar
What subs do you have?
Old Nov 9, 2006 | 12:51 PM
PROxac's Avatar
Parallel is both + together and both - together. The math is
(R1 X R2) divided by (R1 + R2)
so if you had 4 ohm subs it would be:
(4x4) divided by (4+4) = 2
Series is the + from the amp going to the + of sub 1 then the - of sub 1 feeding the + of sub 2 then the - of sub 2 going to the - of the amp. The math is just to add the ohms up (R1 + R2) so two 4 ohm subs in series would be a single 8 ohm load.
Since your amp is good for 2 ohms stereo or 4 ohm mono you cant go with any ohm LOWER than those.
If you have two 8ohm subs then wire them in parallel for a 4 ohm total load (R1 x R2 / R1 + R2)
If you have two 4 ohm subs then run the amp in stereo for two 4 ohm loads or wire them in series for a single 8 ohm load (R1 + R2).
If you have two 2 ohm subs then run the amp in stereo for two 2 ohm loads or wire them in series for a single 4 ohm load (R1 + R2).
If you have two dual 4 ohm voice coil subs then wire each sub in series (for two 8 ohm subs) then wire the two subs together in parallel for a single 4 ohm load (R1 x R2 / R1 + R2 = P1 and R3 x R4 / R3 + R4 = P2. P1 X P2 / P1 + P2)
If you have two dual 2 ohm voice coil subs then wire each sub in series (for two 4 ohm subs) then run the amp in stereo for two 4 ohm total loads (R1 x R2 / R1 + R2).
If you have two dual 8 ohm voice coil subs then wire each sub in paralell for (for two 4 ohm subs) then run the amp in stereo for two 4 ohm total loads (R1 x R2 / R1 + R2).
Old Nov 9, 2006 | 02:51 PM
SSpiro's Avatar
JL W6 10" AE's..
PROxac - I think my head exploded.
Old Nov 9, 2006 | 02:58 PM
styxnpicks's Avatar
series parallel
wire the voice coils on each sub in series then wire the subs in parallel for 6 ohms.... or you can wire each sub parallel then run it in stereo with each sub @ 3ohms since your amp is stable in stereo @ 2
Old Nov 9, 2006 | 03:08 PM
brypink2's Avatar
JL W6 10" AE's..
Those are dual 6 ohm subs. Wire them in series and you will get a 6 ohm final impedance. Or you can wire each sub parallel (individual), then run each sub to a channel (stereo).
Do you have an amp for your speakers? If so, what is it?
EDIT: Well, styx beat me to it.
Old Nov 13, 2006 | 08:42 AM
SSpiro's Avatar
Alpine MRP-F240 Amp for mids/highs.
