Factory wiring question
Positive seems to be the one closest to the release button on the connector. To confirm, take a 9V battery and a couple of test leads and touch the speaker connections the positive battery post will make the woofer cone push outward. If you touch the other terminal with the positive lead the cone will draw inward.
here you go man, these will make your life easier, I've got 2 pair no probs.http://www.crutchfield.com/S-Gd1CKxR...100&I=12071048white is positive black is negative.
