MTX Thunderform Install w/Pics
Old Oct 11, 2006 | 11:03 AM
Metalcop's Avatar
Over the weekend, I tackled my Thunderform install. Pretty simplistic unit, especially when compared to some of the systems on this forum! For starters, MTX's instructions are pretty much useless. There are huge glaring errors, and they are very basic, meaning they make blanket statements, with no guidance, no description, no actual instruction. Hopefully my trial and error install will help anyone using the Thunderform. I should mention that I have a 2006 Supercab truck, for reference. 1st thing I ran the wiring 'harness' lol. The wires all tuck nicely, behind the seats, just under the carpet lip. Getting them in there, behind all of the seatbelt brackets etc. was alot of fun! I actually rubbed the skin off of a couple of my knuckles, stuffing my hands in and out of that tight seat joint, about a thousand times! I found a nice grounding point, on one of the bolts that holds down the jack.
I spent the better part of an hour, banging my head into the wall, trying to route the power wire into the engine bay, up to the battery. I did not want to drill any holes in my brand new truck! I noticed the antenna wire going down into the fender, and it could (somewhat) easily be seen, up under the passenger footwell. I thought if worse comes to worse, I can enlarge that hole, and install a new grommet. Turned out to not be necessary. Once the splashguard was moved out of the way, I found a nice 3/8" hole in the firewall, just under one of the main wiring harness holes/grommet. It is unused, and is only covered with a sticker.
I installed a couple of grommets on the power wire, to ensure that no water or whatever, found its way into the passenger compartment.
Next, I routed the speaker wires. These simply tap into the existing rear speaker wires, making it unnecessary to run lines up to your head unit. I'm 99.9% sure that the factory head unit does not have RCA outputs, at any rate. The MTX directions state that the speaker wires run under the drivers side threshold?! Hmmm, doesn't make sense to me, but I stupidly run both sets of RCA cables over to the drivers side. I know, I'm an idiot. I am only able to finde the LH speaker wires, of course, the RH wires are on the passenger side threshold, duh. Thats what I get for taking these 'directions' too literally. Meaning I have to reroute the passenger side RCA cable, meaning a couple more mm of knuckle skin worn off! After that, It was smooth sailing, the box screws right in snugly, and actually sounds quite good for what it is.
I nearly forgot to mention, I mounted my remote speaker volume ****, in the center console. Again, no way I was going to drill out the dash or wherever for this (kind of cheesy) ****. Also, there was no way I was attempting to run any more wires, any further than I had to. I give Ford credit, this truck is well put together, this was one of the harder installs I have done. Simply because there isn't much space, and things don't just come apart easily etc. Here's the volume ****:
My post isn't meant to replace the instruction that MTX provides, merely augment them, since they are woefully lacking. Hope this helps.
Old Oct 11, 2006 | 11:05 AM
Metalcop's Avatar
Couple of additional pics
Here are some pics of the final install>
Old Oct 11, 2006 | 11:20 AM
06FX4's Avatar
pics no worky lol
Old Oct 11, 2006 | 01:22 PM
Impact9's Avatar
Originally Posted by 06FX4
pics no worky lol
Works for me.
Old Oct 11, 2006 | 01:26 PM
06FX4's Avatar
Originally Posted by Impact9
Works for me.
maybe its just my school computer? lol
Old Oct 11, 2006 | 03:05 PM
06FX4's Avatar
pics work now for me lol, looks really good!!! i want one, but i dont need the amp or the sub lol
Old Oct 11, 2006 | 04:06 PM
Metalcop's Avatar
Where to buy
I bought mine from Supercrew sound. The guy I dealt with (Mark?) was really cool, and I received the product quickly, even though it was not in stock. I saved a whopping $150 buying from Supercrew, instead of Crutchfield or another 'authorized' dealer. BTW, you can get just the box, with no amp, and you can even delete the sub, if you want to use your own (subtract $40, I think). Right now I am using my Ipod, with a wireless FM transmitter, so the quality is not that great. This sub is more than I need, in such a confined space. However, I am not into the thumping bass that can be heard from a block away, lol! I am just an old school headbanger...
Old Oct 11, 2006 | 07:40 PM
brypink2's Avatar
Mark is a great guy to deal with! And, congrats on your system!!!!
BTW, I'm an oldschool headbanger...what's that got to do with hearing a system from a block away? LOL
Old Oct 11, 2006 | 08:24 PM
Bartak1's Avatar
Lookin good
Old Dec 22, 2007 | 07:58 PM
AirborneRacer's Avatar
So are you happy with the quility of the materials for the subbox? Is it flimsy or thick material?
Old Dec 22, 2007 | 08:06 PM
wookie13's Avatar
would a jl 10w3 work in that box? i like the mtx box just dont like their junk subs and amps!!
Old Dec 24, 2007 | 09:37 AM
Devildog101's Avatar
That box is for a 12". You could probably make it work though, if you really wanted to. There are other single 10" boxes to be had cheaper though.
Old Feb 21, 2008 | 05:17 PM
freekyFX4's Avatar
Cool write up. I will be using this when i install mine next week. To anyone who has one of these...is the plastic enclosure pretty strong and sturdy or is it really thin and flimsy?
Old Feb 22, 2008 | 02:03 PM
davewvu86's Avatar
I have a single 12 thunderform in my 2005 supercab. I bought it unloaded for $100 when sounddomain.com was having it's close out sale. I put a JL 12w1-8 in it. I have 500watts going to it and it sounds great. The box is pretty stout and the plastic is plenty thick.
For the price, convenience, and the ability to have a 12" I don't think it can be beat.
Old Feb 22, 2008 | 02:58 PM
freekyFX4's Avatar
Thanks! I paid a lot more for mine loaded with the Thunder 4500's. I wish I had gotten it unloaded for $80 less and bought the Thunder 5500's or some other shallow mount 10" subs.
