amp advice...
Old Aug 5, 2006 | 05:23 AM
bubba102105's Avatar
amp advice...
Just ordered a custom box and 2 10" L7 subs. Anyone have any advice on what amp I should get to push these? Let the opinions roll!!
Old Aug 5, 2006 | 04:09 PM
dconder's Avatar
Budget?? Are the subs dual 2 or 4 ohm.
Old Aug 5, 2006 | 04:16 PM
amp advice
Dual 4 ohm voice coils
1200 watts max power handling
600 Watts RMS power handling
85.7 DB sensitivity
frequency response: 24 - 100 K
Not looking to spend too much on the amp. I was looking at a new volfenhag. Would this work good with my set up?
Max Power: 2,400 watts
Channels: 2 Channels
Built in top mounted turbo fan
Built in full high pass and low pass crossovers
Bass Frequency: 30Hz - 100Hz
Variable Bass Boost: 0 - 18 dB
Frequency Response: 20 hz - 20 khz
THD: .03 %
High pass filter frequency 50 Hz - 1 Khz
Low pass filter frequency 30 Hz - 250 Hz
Adjustable input sensitivity
Short / Circuit / Thermal / Overload protection
Soft Delayed Remote turn on
Tri mode capable
Fan cooling system
S/N Ratio 97dB
Mosfet switching power supply
Gold speaker and power connector terminals
Phantom channel for powering center
Old Aug 5, 2006 | 05:05 PM
brypink2's Avatar
85.7 DB sensitivity
THD: .03 %
Tri mode capable
Fan cooling system
S/N Ratio 97dB
I don't think I'd get the Volfenhag. Alot of guys on the car audio forums have had good results with Hifonics. They are not an amp I would recommend, but you are looking for inexpensive.
You need something 1000-1200 x 1 @ 1ohm. An option is to buy used...there are tons of amps on the different car audio forums. Just becareful buying from someone on the internet...research the individual first for references. You can get a better quality used amp in your price range vice a lower quality new one.
Good Luck.
