Sub box help....
Old Jul 15, 2006 | 12:56 AM
ROLLINGon38'S's Avatar
Sub box help....
I have a 97 ex. cab F150. And right now i have 2 10's in the back. And both of them have there own boxes. So they are verry small. But my question is, that i'm making a new box that will take up all the room under the back seat ( I made my own 3in seat lift) So this box will also be sealed, so am i going to notice a big differnce with the sups have more air space. Or is it just a wast of my time? And also since both of the subs will be in one box should there be something spliting it in the middle or should i just leave it open inside?? Thanks
Old Jul 15, 2006 | 02:04 AM
sed2208's Avatar
Not a waste of time that's the way to go. you will hear a big diff. more air space more bass. And yes put something in the middle to split them, give them there own space.
Old Jul 15, 2006 | 02:23 AM
Socal858's Avatar
they will be deeper and louder. your sound quality can improve or diminish depending on how close your current box is to recommended specs and the airspace in the newer box
Old Jul 15, 2006 | 02:28 AM
alright... Thanks.... so should i just put it in the dead middle or what, because wont the cut out for the seat mount make one side smaller then the other side? Or would it not make that much of a diference? And also i have been told that down fire is best, but with the boxes i have not when i turn them over so they fire up it seems to be a lot louder....So what way should i have the fire? Thanks.....
Old Jul 15, 2006 | 02:31 AM
Socal858's Avatar
ive heard both, do what you like better. build the box to go around the seat mount and have them share airspace, its ok that way
Old Jul 15, 2006 | 02:43 AM
Ok i will do....But i have been told they need there own air space. so what will it do it they both are sharing the air space....and also i have heard about puting that fluffy stuff in the box to make it sound better, should i do that??? Thanks......
Old Jul 15, 2006 | 02:46 AM
Socal858's Avatar
the fluffy stuff doesnt do too much im not a big fan. they dont need their own airspace. just take the recommended airspace and double it, build your total box volume to match (or exceed by a little).
if youre trying to build each side the same it takes some complex calculations and precise boxwork, because even small differences will cause cancellation and reduce both soudn quality and output
Old Jul 15, 2006 | 03:01 AM
Ok, I'm not to sure of the recommended airspace... I'm just making it as big as i can under my back seat...Also it would be better if it is sealed right?....
Old Jul 15, 2006 | 12:15 PM
Socal858's Avatar
stick to sealed for now, ported requires a lot more calculation and math to get right
Old Jul 15, 2006 | 02:34 PM
Alright thanks, I will make it sealed then....
Old Jul 15, 2006 | 02:45 PM
bubba joe's Avatar
Its a good idea to match the subs to their recomended air space, what subs are they?
Old Jul 15, 2006 | 02:52 PM
Well i found some info on my subs, and I'm guessing they need 0.75ft^3... does that sound about right? My subs are 10" infinity Reference 1042w.....
Old Jul 15, 2006 | 03:21 PM
bubba joe's Avatar
for those subs that its correct .75ft^3 so that is a pretty small box. These wont perform as well if you give them too much air space.
Old Jul 15, 2006 | 06:22 PM
So should i not wast my time making them a bigger box? or should i just devided the box in the middle.....to get the air space these subs need what would the box size have to be?? Thanks
Old Jul 15, 2006 | 07:36 PM
Radio's Avatar
A ported box will be twice as loud if tuned right. .75 cubes is about right for the minimum volume.
