Help wiring powered Bazooka sub
Old Jul 6, 2006 | 04:38 PM
bamorris2's Avatar
I'm trying to get a mental picture of what the wiring schematics would look like if I added a powered Bazooka sub to my truck. Currently, I have a stock HU, a 4-channel Alpine amp, and speakers at each corner. Behind the HU, I have LOC's, then RCA wires running back to the amp, then speaker wire going back up to the rear of the HU...
Now how/what wires would I need to run to the Bazooka?? It needs inputs, right? But from where? If I were to connect my speaker wires to the Bazooka, then my speakers wouldn't work, right??
Obviously I'm a total novice when it comes to audio connections... What I need to know is literally, what get's plugged in to/from where... The power/ground/remote I understand, but the input and output signals I don't.
Old Jul 6, 2006 | 07:50 PM
Bartak1's Avatar
What I would do is go buy a pair of RCA Y-splitters. Plug them into one of your LOC's, then hook the RCA's that go to your Alpine amp up to the splitters, then another pair of RCA's and run them back to your bazooka tube.
You COULD tap into your speaker wires and run wire back to the high level inputs on the tube (assuming it has high level inputs) but getting RCA splitters and another RCA cord is much easier.
Dont forget to buy two splitters, and make sure they are one male end that goes into two female ends.
Old Jul 6, 2006 | 10:07 PM
bamorris2's Avatar
Ahhh, very clear now. Thanks!
One more quick question: It looks like Bazooka makes 2 versions of each of their powered subs; a 2 ohm and a 4 ohm. Which one should I get?
Old Jul 6, 2006 | 10:45 PM
Bartak1's Avatar
If the sub is powered and has its own amp, I dont see why it would make a difference. Are the two units rated the same as far as wattage goes?
Do you have a link to these two versions?
Old Jul 6, 2006 | 11:14 PM
bamorris2's Avatar
Ok, so I just went to their website again to double check it, and it was the passive tubes that each have 2 versions... The powered tubes only have 1 version.
Thanks...
Old Jul 6, 2006 | 11:18 PM
Bartak1's Avatar
Thanks...
Gotcha
No prob.
