2004 speaker replacement
I am looking at replacing my rear door speakers on my 2004 fx4 and I am not sure how to remove the door panel? I all ready replaced the fronts with kenwood excelons and would like to replace the rears as well. can anybody help I would not like to pay someone to do this? I have put in many other car systems I am not sure how the rear panels come off.
thanks
antelope555
thanks
antelope555
1. Pry out narrow window trim. Remove one exposed 6mm screw.
2. Pry out wide window trim to release 4 retaining clips and remove. Remove one exposed 6mm screw.
3. Pry out screw cover on door release handle. Remove two 6mm screws and remove handle.
4. Remove 1 6mm screw from bottom of door panel.
5. Pry up power switch panel and disconnect to remove. Remove 1 10mm exposed screw by removal of switch.
6. Lift door panel to remove.
Sorry...don't have pics. But it is pretty easy... I used to have a link to the instructions but I can't find it. Only have a hard copy now...they are from crutchfield.
