? about sub boxes.
Old Jun 11, 2006 | 12:23 AM
RRf150's Avatar
? about sub boxes.
what upp?
im getting two 10 inch subs and an amp to put under my back seat... 1)will they fit and 2) where can i find a box? will best buy make boxes for this? I have an '05 stx supercab. i know that the jack is under the right side of the seat, can that just be removed and put somewhere else?
i am a nuub at this whole thing, so as much help as possible would be awesome! thanks
rob
Old Jun 11, 2006 | 09:54 AM
97f250's Avatar
Originally Posted by RRf150
what upp?
rob
You will not be able to get TWO 10" subs AND the amp under the seat. Maybe look to mount the amp under the front seat.
Old Jun 11, 2006 | 02:46 PM
02SC4x4's Avatar
I have a supercrew and right now the box is sitting on the back seats. My one amp is hidden were the jack was behind the rear seats, in a little compartment. and the other amp is on the other side. Go to a car audio shop and the guy there should have a whole bunch of magazines with different size boxes for and car/truck out there. Or you can go to www.supercrewsound.com and look around there. And yes they have ext cab too. You cold prob fit both subs and an amp under the seat, you just have to put the subs facing down, which is what all the boxes for trucks will have you do anyway. you might have to get 8" subs, or just find a 10" that is a very shallow sub. my jack is now under my front seats. move things around, you can make anything work. hope this helps.
Old Jun 12, 2006 | 03:28 PM
TXhustla's Avatar
I have a question what would type of box would POUND the hardest in a single cab 04STX. I listen to rap and have 2 10 Memphis on a Coustic 800D
Old Jun 12, 2006 | 03:42 PM
pb4life's Avatar
www.subthump.com has some sub boxes
Old Jun 13, 2006 | 03:15 PM
TXhustla's Avatar
Those are just sealed, universal at that. What will POUND the hardest....................
Old Jun 13, 2006 | 03:56 PM
Ray Knobs's Avatar
Your neighbor with his baseball bat when you come at 2am with that crap cranking.
Old Jun 14, 2006 | 01:27 PM
quicksilvertex's Avatar
iyes u can fit a amp and 2 10s i had it in mine till i completely redid my interior if possible (a lil extra money) try to get them to downfire and ull get more bump
good luck
Old Jun 14, 2006 | 01:53 PM
BRW619's Avatar
Anyone have one of these? If so is it worth it?
http://www.crutchfield.com/S-1RFloz6...0&I=236F150CCT
Old Jun 14, 2006 | 02:21 PM
TXhustla's Avatar
good luck
Can downfires go in a single cab?
