New subs installed
New subs installed
just got 2 JL 12's installed in the truck. single cab 04 f150...
noticed something...the bass has a slight delay over the actual beat...just barely enogh to notice. could the problem be that i have them hooked up to my facctory cdplayer? i havent gotten an aftermarket recv yet...any ideas on whats up?
noticed something...the bass has a slight delay over the actual beat...just barely enough to notice. could the problem be that i have them hooked up to my factory cdplayer? i havent gotten an aftermarket recv yet...any ideas on whats up?
If you are powering them up with an amp try running them out of phase. What I mean is take the positive speaker wire off the amp and put it on the negative terminal of the amp, then take the negative speaker wire and put it to the positive terminal on the amp. If you have any questions regarding this post them, it is as easy as it sounds but ask if needed. If you are running them straight off the radio, go buy an amp. I think thats what Rkymntfordfan was getting at.
Playing the subs out of phase does not hurt the equipment sub/amp etc. it simply plays the sound reversed which may actually couple to the sound from the fronts and sound better. Even if it sounded good its always an easy thing to try to see if it would sound better.
