3 way component set
Old Apr 18, 2006 | 09:02 PM
SKRWZ's Avatar
Originally Posted by brypink2
What have you done to your doors (where your components/midbass) are in terms of installation? What about the rest of your truck? Properly matting and sealing up your doors will more than likely make you happy and it's alot cheaper than buying new/more speakers.
Never skimp on the install, even if you are just putting a modest inexpensive system in.
Sorry for the long post but here's your awnser,
The rest of the truck has 2 type R 10's each powered by thier own v 12 mono amp mrd 605's the airspace of the box is 1.6 cu ft minus the volume of the subs witch are 0.050 each so internal volume should be 1.5 cu ft if thats's right the box is a single chamber, "test box" right now,(the final one will be built this weekend hopefully) i think and the four channel is a alpine v 12 mrd 345 in the doors are alpine component type R's and the tweeters's are on mirror mount covers, also as for now the rears are some JL audio 5x7's but i am going to take them out and use them in the wife's focus i probly dont want any rear fill, in my truck with those 10's you cant hear them any how and thier wasted so i sooner just get rid of them, i just got my order of sound deadner matt in yesterday (B quiet extreme) and that should go in on the weekend as well, as for buying more speakers i already have a new in the box set of type R components here if i wanted to use them for the kick panels if i chose to or put them in the focus as well or sell them that dosent matter.
what i had thought of doing orignally was using the other set of components up front in some kick panels and a pair of component's in the doors and the tweeter's on the "A" pillar dash area, or getting kick panels with the type R's in them and adding a mid bass driver in the door's, or add a 3 way set up like the orignal question.
dconder. from what i saw on the Q logic site the kick panel's will take up to a 6 1/8 driver and read somewhere they may fit a driver slightly larger and the type R's are 6 1/2 so who knows if they will fit without looking at them
Thanks alot for the relpy's I appreciate the responses
