custom sub enclosure... peep this
Old Mar 23, 2006 | 02:28 AM
FatGrib's Avatar
check this out... anyone got one like this?
https://www.f150online.com/galleries....cfm?num=10791
Old Mar 23, 2006 | 04:31 AM
RageOfOrder's Avatar
I can't possibly imagine that sounding good.....
Not mounted in a plastic door panel anyway
Old Mar 23, 2006 | 12:30 PM
FatGrib's Avatar
its in a box, the box is fiberglassed to the panel.
Old Mar 23, 2006 | 07:49 PM
BigShoesHritge's Avatar
mines in the back seat i got the thunderform box with 2 10's with built in amp
Old Mar 23, 2006 | 10:49 PM
Rider69's Avatar
I like the concept of that. It looks awfully close to the seat, so is excursion a problem? What kind of interior volume did you get out of the box in the door?
Old Mar 24, 2006 | 01:14 PM
FatGrib's Avatar
there is a raised lip around the sub itself, and the sub is low excursion, so it doesnt hit the seat, as far as interior volume, great, filled in all the gaps behind the panel with foam filler, plus lined the back with matting (similar to dynamat), sounds beautiful
added pics of the custom tweet houses too
Old Mar 24, 2006 | 01:22 PM
frostby's Avatar
Here's a quicky peek..
Old Mar 24, 2006 | 01:25 PM
frostby's Avatar
I'd like to hear that first hand as well, my compliments on the handiwork and idea... although I also wonder what kind of actual volume the sub has to work with, it seems rather minimum... anyway, you shared and thank you!
Old Mar 24, 2006 | 01:42 PM
b_j__h's Avatar
You did a good job with the fiberglass. It looks like it was part of the door.
Old Mar 24, 2006 | 01:48 PM
Zaairman's Avatar
Bondo on the sub??? I'm guessing it hit the seat?? Other than that, it looks great! I built this box myself for two Memphis 12" subs, and I also made the 4" seat lift. The vinyl looks crappy in the pic, but it sounds great, so I'm happy.
Old Mar 25, 2006 | 09:52 AM
2fast4u2's Avatar
Thumbs down ugly looking
personally i think that that is the dumbest thing i have seen ANYONE do.Do you actually think that is gonna sound good at all?and if it does it wont for long.you will have paint starting to crack and alll kinds of stuff go wrong....good luck with it LMFAO
Old Mar 25, 2006 | 11:32 AM
GA FOO 88's Avatar
That 5x7 is useless next to the sub, but the install looks nice except for the stuff on the cone. Some 8 inch mids in the front doors glassed like that wood be sexy.
Old Mar 27, 2006 | 01:00 PM
FatGrib's Avatar
nope just an old blown sub with a new life
Old Mar 27, 2006 | 01:23 PM
FatGrib's Avatar
i should mention that this has been in for more than a year now, with no problems, still hitting like a new sub, even with the bondo, and there are no cracked paint problems(i dont see how there could be), or any other type of problems for that matter... except maybe i should paint that bondo, i admit, its a slight ugly, but it doesnt sound ugly
Old Oct 9, 2012 | 10:37 PM
JHL's Avatar
JHL
Pretty simiar to what I did...
I truly doubt that big boy has sufficient air space behind it!
This one does! And its designed to work in a small enclosure.
I used an Image Dynamics ID8 V3 D4 and my box was approx .5 cu ft., which is ideal for this woofer.
I have 2" between speaker and seat and no problems with cone excursion!
