room for subs?
Old Mar 15, 2006 | 03:20 PM
calisonic's Avatar
room for subs?
is there anywhere that 2 10's would fit in a '93 standard cab?
Old Mar 15, 2006 | 04:28 PM
RageOfOrder's Avatar
Yes and no. Depending how big good you want these subs to be.
You would probably be best to get a hold of a couple Bazooka 10" Tube subs off e-bay or somewhere. I don't think there is much room behind the seats in a 93, so the tubes are your best option.
Otherwise, you could buy seperate subs and have a custom box ordered that will hold them, as long as the mounting depths and air volumes are acceptable in the box.
I could only fit a single 10" into my '00 reg cab, but then it's an SPL sub with a mounting depth over 6" deep and requiring at 1 cubic foot of volume in the box.
Old Mar 15, 2006 | 08:29 PM
GA FOO 88's Avatar
You can easily find 8s with a mounting depth of 4 inches, meaning you could have a 6.5 wide box propablly, take some measurements behind the seat, and see what you can work up.
Old Mar 15, 2006 | 10:12 PM
nothinbutaford's Avatar
Also Rockford has the new shallow mount p3 10" subs that may fit where you need. And don't forget if you can't fit 2 subs you can always make up volume with more power.
Old Mar 16, 2006 | 12:19 AM
Pioneer has some 10's and 12's with < 4" mounting depth, might also be worth a look.
