Audiophile question?
Old Mar 13, 2006 | 04:32 PM
91trunk's Avatar
I just leased a S/C XLT. It has the 6 disc in dash. I'm wondering if the the wiring for the Audiophile is run for the subwoofer from the kick panel to the back?
I know the wiring isn't there from the radio to the kick panel block.
I'd rather not tear the whole thing apart to check. Any info would be nice
Thanks!
Old Mar 13, 2006 | 10:55 PM
nu-supercrew's Avatar
Look under the rear seat, drivers side, right next to the seat mounting bracket. There is a slit in the carpet. Feel in and around there for the harness which should be screwed down to the bare floor. You may have to enlarge the slit in the carpet. I don't think you will have it. I just went through the same thing with my XLT. Wasn't there. I believe only FX4's and up will have part or all of the harness. If you need the part #'s to make the harness do a search or let me know, I still have the bags they came in.
Old Mar 19, 2006 | 10:16 AM
ChandoJMC's Avatar
Did you end up making your own harness? I bought all of the stuff...just haven't had the time to work on it. Did you tap into the fuse box or run a power wire from the battery? That is the only thing stopping me from wiring my sub up...
Old Mar 23, 2006 | 03:50 PM
boosted306's Avatar
Part numbers??
I could really use those part numbers. I need the harness from the radio to the kick panel and the kick panel to the sub. Did you replace your head unit as well?
Old May 16, 2006 | 03:22 PM
FoMoCoEmployee's Avatar
Hey NU, I believe I need those numbers as well. I happen to have an '05 FX4 screw and its looking like I don't have that harness under the rear seat. Also (I hate to be a pain in the @ss), can you tell me where you hooked up the hu end of your home-made harness?
Any info will be MUCH appreciated.
