What to do?
What to do?
I have 2006 Ford F-150 Supercrew with no room under the back seat. I listen to all types of music, but tend to concentrate on country and hip-hop. I am not concerned with rattling the windows down the block, but I do want good, clean, solid bass. I am considering two options:
1. Two 8 or 10 subs facing up under the seat. Approx. box volume is .5cuft each and allowable mounting depth is 5. I am concerned about sub excursion into the bottom of the seats and allowable depth.
2. Two 8 (possibly four) forward firing subs. Will be a very tight fit, depth is not a concern, and box volume somewhere between .3-.5 cuft each.
As far as subs are concerned I am thinking Kicker L5s or L7s compared to JLs. I will provide each with power as required.
Any opinions would be very helpful. Thanks.
An Adire Koda has a 4 1/4 mounting depth, a single Koda 10 with 400 RMS going to it will be perfect. That way you will have enough room for excursion and place for amp under seat. Adire is a SQ sub and will sound better than JL and cost less. JL you pay for name. IF you want clean bass, stay away form kicker solo barics, they are a spl sub and you will not get clean bass.
Thanks for your comments. I think I will get some foam and see what I can come up with. It may be time to look at other box materials. Has anybody every seen or heard a box made from aluminum? If fiberglass came into play how thick should it be?
