2000 expy front door speaker grilles cant remove
Old Feb 22, 2006 | 04:35 PM
cardinalworks's Avatar
Unhappy 2000 expy front door speaker grilles cant remove
trying to remove drivers side door speaker premium sound
grille wont budge...broke 2 of the plastic catches trying to pry off
do i need to remove the whole door panel? help!
Old Feb 26, 2006 | 08:43 PM
Flareford150's Avatar
YES! The entire door panel needs to be removed. Always research that kind of stuff before prying things.
If it's a 2000, this should work on removing the door panel:
Remove plastic pillar piece mounted on rear of door
Remove Panel surrounding door handle w/ Flathead Screwdriver
If you have power Windows+Locks; Remove the Instrument Panel on your Driver's door. Use the flathead and gently push up on either sides of the panel.
After you do that, and remove all of the screws. You should be able to SLIDE the door up until you feel a release, then remove the door.
