Component Tweeters Not Fitting
I just put in my Alpine Type R Component system in my 04 Scab. I got everything installed and wired up and went to put the plastic cover pieces back on and the top part won't snap in because the tweeter is sticking out too much. I was wondering if anyone else has had this problem and what they did about it. I'm going to try to sand (with my dremel) a little bit of the inside material away and see if I can get some more room for it to fit. I was also thinking of just cutting the hole out in the plastic piece and covering the whhole plastic peice with some kinda of thin material (like panty hose) but I'm not sure if it'll work. Any ideas or suggestions???
Not sure about 04, but my 05 had a hole already there for a tweeter. I just had to use the dremel and make the hole slightly bigger for my tweeter to fit into. It all then nicely fits behind the black plastic cover. Are 04s that much different? I am in Orlando, so if you need some help, let me know.
yeah, My 04 is the exact same way. I just dremeled the opening out a little bit. The problem is that it sticks out too far and the plastic piece won't snap back onto the door panel.
Can you possibly take a picture of how you have them mounted, as I have 1 Type-R tweeter mounted in one of my doors (awaiting replacement to my RE tweeter) and it fit fine. So I am curious as to how you are mounting them.
I had this issue as well. I had to get a 2" hole saw and blew a larger hole through there. The tweeters then rested in the spot and cover fits.
I just put up some pics in my gallery and one is in there of the tweeter. I am thinking of just taking the metal grill off the tweeter b/c it looks like it will clear if that is removed..
This is silly, but I cannot figuire out how to view your gallery. I am thinking I have the same problem coming up, but wanted to take a look at what you have. I have always viewed galleried from a link on in the post.
Dave
Dave
Well, another option is to take off the entire door panel and mount them from behind the panel somehow. that way, only the tweeter itself will come through the hole and not have to worry about the entire tweeter housing.
firearm
