who has components on their SCrew? installation questions...
Howdie y'all
I just got me a set of alpine type X components and will be installing them this weekend. I can see that there is a spot where a tweeter could be mounted high behind the door panel. Also, I have been told that I need to fab a bracket because the panel is formed for a 5x7.
Is this true? if so, what have y'all used? MDF? One last question, how do I remove the panels? I started messing around with them and I couldnt see a way to remove it without doing some serious jerkin' around of the panels.
Thanks for your help!
JC
El Paso TX
JC
El Paso TX
you dont need to take the whole car panel off just the mesh pastic part. There is a space where you can place a flathead in the top right of the mesh (driver's side door). Top left on the passenger side.
