System 04
Old Jun 22, 2005 | 11:10 PM
chrisrud15's Avatar
System 04
Anyone hooked up an aftermarket amp and subs to their 6 disc changer? If so what method did you use?
Old Jun 26, 2005 | 01:01 AM
vhewitt's Avatar
I am going to do just that I was told use 2 line out convertors 1 for front speakers and 1 for the rear this will allow you to hook up an Amp. I bought the Infinity kappas 6X8's all around. I will be using the Rockford FosgateP4004 to power them. Next I want to install the sub box with 2 10's. I can let you know how it turns out. I just dont like the look when you remove the 2 din stereos and put in the 1 or 1 1/2 to me it does not look clean.
Old Jun 27, 2005 | 12:39 AM
chrisrud15's Avatar
I bought and installed pioneer 3 way 6X8 today. SOunds great. YOu said you are running your 6X8's with an amp? I am running my off the stock head unit. WOuld you recommend running them with an amp? I was told to run the line output converter to the amp via the rear speakers. If you have the 6 disk in dash you dont want to take the head unit out b/c it may cause the air bag to deploy. I will be putting my 12 in. subs in this week. Again should i run my 6X8's with the amp? would it be too much power?
Old Jun 27, 2005 | 06:56 AM
ONE04FX4's Avatar
Talking
i had my 6 disc head unit out sevral times before i finally replaced it with an alpine head unit. what is the rating on the 6x8. that is what you need to find out to be able to choose the correct amp.
