Subwoofer wont play help please
Have a AVIC-N1 installed its all brand new kicker 200 amp and 10" in a ported box. But no sound will come out i even hooked to differnt speakers and nothing so I assume its a setting. Any ideas on what it could be??? Thanks
Did you have it installed at a shop, or did you put it in yourself?
If a shop put it in, take it back to them.
Is the amp turning on at all?
Check all your fuses, wires, if the HU has sub outs make sure they arent turned off, check your ground.
Check those things for now.
Hope this doesn't sound condescending, but does the amp have high and low inputs? If it does, the speaker leads on a premium radio in many models coming out of the radio are low. The leads directly to the speaker are high. They must be hooked up correctly or "wone work"
Maybe try putting in different rca's. Also, maybe the inputs or outputs on the amp or HU have a bad connection and have to be "just right" for it go.
