Series-Paralel Wiring?
Old Jun 6, 2001 | 10:12 AM
Tweeter150's Avatar
Question Series-Paralel Wiring?
What is the best way to create the wiring? Would it be better to us a terminal block to split the speaker wire to each sub, or to solder two wires to one. Is there another way to do it that would be better? Im still figuring this all out and I appreciate all info.
Thank you
99 F150 Reg Cab Short Bed 4.6L
Dual Cat Back W/0 Mufflers
K&N Filter
Old Jun 6, 2001 | 11:02 AM
tlapan93's Avatar
Post
Tweeter,
It all depends on how you are trying to run your amp... Are you going to bridge it or run it as 2 channels?? If you are going to bridge the amp to run 1 channel then sloder both of the wires together and run 1 positive and 1 negative to your amp bridging 2 channels in to 1... the owners manual will have the specifics. Personally I think that is the way to go- It will pound... Oh by the way, are you doing this for a sub box?
98 Ford F150 Supercab stepside 50th Anniv. Completely stock----- for now.
93 Mustang GT- 600 hp, caged, blown, 10.37@131mph, and passes Mass emissions,
Old Jun 6, 2001 | 11:43 AM
Tweeter150's Avatar
Cool
tlapan,
I am planning on bridging the amp to one channel to run two JL 10w3. I am planning on building two sub boxes to go behind each seat of my truck. Since I am using two sub boxes I need to split the + and - somewhere.
Thank you
K&N Filter
Old Jun 6, 2001 | 01:33 PM
Tweeter150's Avatar
Question
tlapan,
If you run the + and - between the two boxes, where do you link the + and - from the amp into the chain? I am planning on using banana terminals on the boxes. At that point , can I cut the + and - between the boxes in half and solder the amp output there?
Just trying to get it straightned out. Thanks for the help.
K&N Filter
Old Jun 6, 2001 | 06:34 PM
F150Sven's Avatar
Cool
This is how you do it:
+ from amp to + of first speaker,
- of 1st speaker to + of 2nd speaker,
- of 2nd speaker to - of amp.
If this is a 2-channel amp (2 pairs of outputs) then the owners manual should tell you which termial should be jumpered together to bridge it.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
Other Enhancements:
Extang Black Max Tonneau Cover
Keyless Entry Keypad
Eurolite Xenon Fusion Bulbs - Headlights and Fogs
Old Jun 6, 2001 | 09:49 PM
tlapan93's Avatar
Post
Tweeter, That is excatly how i would do it. sven- It would work like the way you mentioned, but only if the subs have dual voice coils.
Old Jun 6, 2001 | 11:23 PM
F150Sven's Avatar
Red face
Oops, that was for series.
For parallel, hook all the +'s together, and all the -'s together. Sorry for the brainfart.
Old Jun 7, 2001 | 12:15 AM
tlapan93's Avatar
Wink
Tweeter,
All you have to do is connect the + and - of each box together, then run 1 + an 1 - to the amp... simple. Good luck
