Finished Construction
Well after tolling with volume calculations (who said we wouldn't use algebra later in life
), and several cuts of MDF board, I finished my box. It has 0.9 cu ft, so it should be plenty for the two 8" reactor speakers. If I need to I can retrofit a port tube if the bass is too tight.
I'll get some carpeting soon to cover all the mistakes and caulking. I've hooked it up to my Denon (in house) and it sounds pretty good. I'll post another picture later of the completed box with carpeting and installed in the truck.
E.T. 16.728 @ 85.865 mph
2000 2W F150 (Flareside Black ExCab) 5.4L (3.55LS) with K&N FIPK,Crazyabout150's JetChip *thanks*,Custom phenolic TB spacer, Flowmaster Delta 40, Twin dual 3" pipes out the back, BioLight Xenon Lamps (cool blue), Blazer 55W projector fog lamps, and Stock Ford Sport 17" Rims. Check out the site for spacers that I'm making and other install pictures. http://communities.msn.com/EnvironmentalDamageInc
), and several cuts of MDF board, I finished my box. It has 0.9 cu ft, so it should be plenty for the two 8" reactor speakers. If I need to I can retrofit a port tube if the bass is too tight.I'll get some carpeting soon to cover all the mistakes and caulking. I've hooked it up to my Denon (in house) and it sounds pretty good. I'll post another picture later of the completed box with carpeting and installed in the truck.
