Volume Questions?
Old Mar 27, 2001 | 03:01 PM
5150PhD's Avatar
Cool Volume Questions?
Well I've had enough of the sub-par sound out of my factory CD player. I've got two 8" woofers and a 250 watt amp. How much volume to I need for a box (to fit under the ext cab seat) and what size of porting would you guys recommend?
Any information would be appreciated.
2000 2W F150 (Flareside Black ExCab) 5.4L (3.55LS) with K&N FIPK,Crazyabout150's JetChip *thanks*,Flowmaster Delta 40, Twin dual 3" pipes out the back, BioLight Xenon Lamps (cool blue), and Stock Ford Sport 17" Rims. Check out the site for spacers that I'm making and other install pictures. http://communities.msn.com/EnvironmentalDamageInc
Old Mar 27, 2001 | 07:58 PM
f150intally's Avatar
Post
You should start out by researching the subwoofer manufacturer you are interested in using and research their volume requirements for their subs. After you determine that, you will want to take one of two actions: Buy a pre-built box with matching volume or have someone build you a custom box that meets your volume requirements. You can pretty much count on most 8's requiring .30 to .50 cubic feet per speaker. If you can get a box with .70 cubic feet of airspace, you will be o.k. That will be a sealed box, though. Ported boxes require significantly more air space, therefore are very limiting for our situations. Some of the prebuilt box manufacturers include:
Q-logic http://www.airesearch.com, Mtx http://www.mtxaudio.com, & JL Audio http://www.jlaudio.com. Hope this helps.
Thanks.
- Jay
Old Mar 27, 2001 | 08:09 PM
5150PhD's Avatar
Post
Thanks for the info f150intally...Since it's tax time I'll probably build the box myself. Any advice on box fabrication?
Old Mar 27, 2001 | 08:18 PM
Post
Do a search for "box specifications" or "box dimensions" on this forum. If my memory serves me, there was some guys that were offering their dimensions but you had to email them. Most of the boxes are build out of particle board (MDF).
Thanks.
- Jay
Old Mar 28, 2001 | 11:47 AM
5150PhD's Avatar
Post
Thanks again f150intally...I'll report back later with what I find and progress on the box.
Old Mar 28, 2001 | 03:38 PM
sundog7's Avatar
Lightbulb
5150: Another fine site for enclosure calculations may be found at:
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Go to the scrolling menu on the far right side and drop down to "Basic Enclosure Calculations" This presents extensive information to you, and provides several calculators so you can just plug in your numbers and get results calculated for you immediately.
[This message has been edited by sundog7 (edited 03-28-2001).]
Old Mar 28, 2001 | 03:54 PM
5150PhD's Avatar
Post
Great! Thanks Sundog7..I'll check it out
Old Apr 2, 2001 | 01:45 PM
5150PhD's Avatar
Thumbs up
Hey Sundog7....
That site is great. Somebody must have had some time on their hands to build that place!After using the box calculator, I'll have about 1 cu. ft of volume with a 3" x 9" port tube. Should work for my needs. I'll post here when I get the box built and post pictures to my website.
Thanks again for the info!
Old Apr 5, 2001 | 01:47 PM
5150PhD's Avatar
Post
True, True. Do you know if the Ford single disk player has a preamp out? If not then it's off to Circuit City I go for a new head unit.
Old Apr 6, 2001 | 12:45 AM
sundog7's Avatar
Thumbs up
Helping each other out is what this site is all about!! Glad the site was good for you. I'll be looking forward to checking out those pix when you get around tuit.
Old Apr 6, 2001 | 10:56 AM
Big Tray's Avatar
Post
No they don't, but if you're going to get rid of that stock cd player, I may be able to take it off your hands (cheaply).
Old Apr 6, 2001 | 11:56 AM
5150PhD's Avatar
Cool
Hey Big Tray....
I'll keep you in mind when I get around to changing it out with the new head unit.
E.T. 16.617 @ 83.310 mph
2000 2W F150 (Flareside Black ExCab) 5.4L (3.55LS) with K&N FIPK,Crazyabout150's JetChip *thanks*,Custom phenolic TB spacer, Flowmaster Delta 40, Twin dual 3" pipes out the back, BioLight Xenon Lamps (cool blue), Blazer 55W projector fog lamps, and Stock Ford Sport 17" Rims. Check out the site for spacers that I'm making and other install pictures. http://communities.msn.com/EnvironmentalDamageInc
Old Apr 6, 2001 | 02:50 PM
sundog7's Avatar
Wink
BigTray:
Tray from CK???
I've got the 6-cd changer/mag removed from the center console you can pick up cheaply.
Try sundog7@comporium.net if you're interested.
