Single 10?
Old Mar 25, 2001 | 03:56 PM
ChuckM's Avatar
Post
You have a lot of different options available. Start checking the threads here. If all you want is some bass to fill the lacking bottom end of the stock stuff, a single 10 will be just fine. there are a couple of guys using a single 8. Try a local shop and listen to what they have. A sigle sub and amp is not hard at all. MTX also has a dual 8" sub box with a 100watt amp built in. Very easy to install as it has built in speaker level inputs and a "smart" turn-on that does not require a remote turn on lead. the amp "listens" and soon as it senses a signal, it turns on.
97 F-150XL 4.2V6, 5 spd, 2wdlb, Kenwood cd, MTX 4ch amp, MTX 12"sub, MTX components in doors
Future 16x8 Daytona wheels, 265/75 tires, rhinoliner, perf stuff
Old Mar 26, 2001 | 12:28 AM
ilmagill's Avatar
Post Single 10?
Will a single ten be fine for an xtd cab f150? And if so anyone got any suggestions for a single 10 w/box and amp...either sperate or together....and im trying to keep costs as low as i can possibly go.
Things to come: coil spacers, 4.10 gears, Grill
ilmagill@aol.com For Pictures :
www.geocities.com/ilmagill
