Q-logic?
Q-logic?
Hey,
Has anyone installed this enclosure in there trucks?
IC
http://www.crutchfield.com/S-6OCB7op...o&i=044CFFX001
IC
I have heard almost exactly the same thing in a full-size ext cab chevy. It was a good enclosure. It's been a few years...
Don't know what has changed about it, if anything... The only thing bad about it is the price.
If building your own isn't an option, then it will definitely work.
Hey,
Thanks for the info.
I actually found the same enclosure at topedgeonline.com for $55 dollars less.
Any suggestions on which sub/amp combo would best fit this box.
Not knowing much about car audio systems I would appreciate any suggestions that u all may have.
Thanks.
IC
Box Specs
· Internal Volume: 0.65 Cu/Ft
· Cutout Diameter: 9.184"
· Mounting Depth: 5.5625"
· Maximum Frame Width: 11.1875"
Thanks.
IC
Box Specs
ok, ok....this will be the last post of the night.....
i actually did some research online and found four 10" subs that will fit the box. which one do u recommend and why?
Also, what do they mean when they say dual coil etc.....
Rockford Fosgate P210S4
Audiobahn AW1000Q
Kenwood KFC-XW1025dB
Jl Audio10W40
IC
Audiobahn AW1000Q
Jl Audio10W40
IC
