Dash
Old Oct 20, 2004 | 02:06 PM
jdoggfx4's Avatar
Dash
Is the radio in the 04 f150 a double din or is it din and a half.
Old Oct 20, 2004 | 02:38 PM
spr_F150's Avatar
I must admit that I do not know the answer, but you may have better luck posting this in the Other Audio System section instead of the subwoofer section.
Old Oct 20, 2004 | 02:58 PM
rockafella's Avatar
www.crutchfield.com says it's a double din. so you can get a double din deck, din and 1/2 , or a single din w/ mounting kit (you'll have a pocket for storage) . It gives you alot of choices to work with. here's a link to tell you what will fit, decks amd speakers:
http://www.crutchfield.com/S-wKUD9a1...&cc=01&vb=&lp=
rockafella
https://www.f150online.com/galleries...y.cfm?gnum=4778
Old Oct 20, 2004 | 04:45 PM
jdoggfx4's Avatar
Talking
Thanks for the info I guess i'll have to put the dvd palyer in that dash to!
Old Oct 20, 2004 | 05:04 PM
rockafella's Avatar
No prob. I have seen that done in the TRUCKIN mag. several times, just make sure that you talk to someone about avalible install kits, I'm sure they make one for stacking 2 single DIN decks together, but it might be a special order type item.
good luck
rockafella
