Re Subs
Old Aug 8, 2004 | 10:30 PM
shroomjohn's Avatar
Thumbs up Re Subs
https://www.f150online.com/galleries....cfm?gnum=4566 First of all thank you Dupris and eveyone else that helped me out.THese thinks are unbelievable you'd think they were 10's or 12's.Circuit City installed my stuff and were blown away.If anyone is wanting to know what to get Resonant Engineering is the way to go.I still can't believe it's only two 8's back there thanks againMy gallery is listed under shroomjohn haven't figured out how to just have a link I am from the ozarks.
Old Aug 9, 2004 | 12:18 AM
Ray21's Avatar
I can't seem to locate your gallery... there doesn't seem to be a search feature for them either. Maybe log on to your gallery and copy/paste the URL to each of the pics or the album they are in.
I just installed a pair of the RE8s last week and am also very impressed. Check out my thread below...
Old Aug 9, 2004 | 09:46 AM
shroomjohn's Avatar
Well I'll be damned, much easier to figure stuff out when I'm not drinking (my birthday yesterday).Enjoy
Old Aug 9, 2004 | 10:33 AM
Dupuis's Avatar
Re: Re Subs
No problem, congrats. Did you go ported? If so, how much box were you able to get them in? Did the guys at CC know anything about RE before you showed up? Get more pictures of your box and subs up when you get a chance.
Old Aug 9, 2004 | 11:20 PM
shroomjohn's Avatar
No cc had no clue they thought they were some generic brand.They really were caught off guard by them it was sweet.No I went sealed that was also on of the reasons it surprised me how well they hit>y box is a q-logic custom 208 It has 1 cubic foot of space.The guys at re actually said the subs were better suited for 0.70 cubic feet in a sealed box but would still work fine in mine.More pics soon thanks again.
Old Aug 16, 2004 | 11:15 PM
Coronach's Avatar
Question:
Did the guys at RE advise one RE8 in a .7 cu ft box, sealed?
I want to make sure that I'm reading that right.
Thanks,
Mike
Old Aug 17, 2004 | 08:49 AM
spr_F150's Avatar
I would think that he means two each re8's in .7 cubes.
Old Aug 17, 2004 | 08:17 PM
Dupuis's Avatar
It's .217 sealed each and .50 ported each.
Old Aug 25, 2004 | 09:11 PM
GreyGhost1583's Avatar
Hey what are you guys paying for a pair of RE dual voice coil and who are you ordering them from. I just got a quote from Visionary Audio and they quoted me $110 for a pair that were Single 2ohm.
I am assuming most people are going with Dual Voice Coil 4ohm
Old Aug 26, 2004 | 02:39 AM
Ray21's Avatar
I paid about the same...
Since there isn't an RE dealer anywhere near me I got mine directly from RE. The 4ohm DVC subs (with chrome back plate) are the '04 models and the 2ohm SVC models are the '03s. I'd request the prettier '04s if I were you.
Old Aug 26, 2004 | 11:06 AM
Dupuis's Avatar
I got mine from the same place for $95 shipped for 2 of them. Mine are single 2 ohm. Dual 4 ohm coil just gives you more wiring options and the single 2 ohm ones do not have the chrome back plates.
Old Aug 26, 2004 | 09:05 PM
Thanks guys
Old Aug 30, 2004 | 12:22 AM
AllstarE4's Avatar
Could someone explain the difference between the 2ohm and 4ohm subs?
I notice that most amps cliam to put out alot more power at 2ohms, but I never see 2ohm subs.
Could these RE 2ohms be the answer to pushing more wattage?
-Eric
Old Aug 30, 2004 | 06:58 PM
97f250's Avatar
-Eric
There are different ratings for the subs so the user can have flexibility for different configurations for his subwoofer system depending on his amp/amp's capabilities. It's all about Ohm's Law(current and voltage and resistance). An amp will work at an optimum performance level into a certain resistance. Connecting subs a certain way can give you that correct resistance. There is no magic way to get an amp to produce more power than it is capable of. You CAN get more from an amp by lowering the resistance from 4 ohms to 2 ohms, or even 1 ohm, IF THE AMP IS CAPABLE. But if it is not, the amp will crash and burn. You hear people talk about bridging and paralleling and doubling power , blah! blah! blah! But if you don't know what you are doing, AND especially if you have some low to mid quality amp, you will be asking for trouble. There are some high end amps to which all of this doesn't apply. For example, JLAudio makes amps that will produce the same amount of power into any load from 1.5 to 4 ohms. But this does apply to most average amps that are available.
Old Aug 30, 2004 | 07:57 PM
AllstarE4's Avatar
97f250,
Thanks for the response.
I'm unsure of the different ways to hook up the subs to get different resistance. I'm planning on buying a monoblock amp.
I wouldn't need to worry about bridging it would I?
-Eric
