Tweeter Placement
Old May 23, 2004 | 11:42 PM
GreyGhost1583's Avatar
Tweeter Placement
I want to put a tweeter in the top right corners of the front doors. ( Not crazy about the factory placement in the 2004)
I was curious what methods of cutting the hole for the tweeter everone is using. As you probably can tell I a rather new at this and really would like to install my system myself. I'm not cheep just a do it yourselfer were ever possible.
Old May 23, 2004 | 11:54 PM
jpdadeo's Avatar
There’s already holes cut in the front doors for tweeters. Pry the plastic covers off and exposes the front speakers and you will see them.
Old May 24, 2004 | 03:46 AM
Deus's Avatar
A hole saw works well or hole bits for a power drill. The A pillar works well for tweeters. Either on the front face of the pillar or on the back (glass side) of the pillar aimed across the windshield.
Old May 24, 2004 | 10:11 PM
Thanks Deus I am probably going with the A pillar on the front of the face. I have seen a few people using this location and it looks really good.
Can't wait to get started.
Old May 24, 2004 | 11:12 PM
IzInBloOm's Avatar
I used a dremal with a metal bit. A few tips tough, Go slow, the plastic will start to melt and splatter. Use a steady hand, you don't want to mess up the cut.....I put the door panel on my kitchen table to make the cut.
let me know if you have any other questions. They sound much better here then in the stock position.
-ii
Old May 25, 2004 | 08:54 AM
Sticker Steve's Avatar
I've got a set where iz-in has his. They really sound nice up there.
Holesaw, no splatter, no bs just a perfect hole. Door panel must be removed and if you've never done it, make sure to remove the two lower plastic clips that the speakers bolt to.
Old May 25, 2004 | 09:31 PM
Thanks Isin and Steve.
Old May 26, 2004 | 04:56 PM
RED WING NUT's Avatar
IzInBloOm,
I'm gettin' some new components for my front doors and I think I'm puttin' the tweeters where you did. How do the door panels come off? How many screws hold it on and where are they? Thanx
Old May 26, 2004 | 05:55 PM
Old May 27, 2004 | 10:36 AM
NFEmery's Avatar
Hey Slicker.. Do you happen to have one of those blow-outs for a 2003???
Old May 27, 2004 | 10:51 AM
No I don't.
I should have also mentioned that onece all those things are removed, the entire door panel will slide up. Once the panel is off, you will disconect the interior door handle cable so look for that. You unsnap the cable and spin it around till it pops off, like a bike brake cable.
Old May 27, 2004 | 11:07 AM
NFEmery's Avatar
Thanks for the quick reply Steve! I'm not new to removing door panels, just have not done it in a long time!! Last one to go was on a 92 Explorer!! (In about 96!!)
Old May 28, 2004 | 06:27 AM
blackwood808's Avatar
That tweeter position is nice if you like your tweeters nice and bright but if you're into a more true sound you should never mount your tweeters no more than 6 in. from your mids.
Old May 28, 2004 | 08:59 AM
From an SQ stand point your correct. I am running mine in combination with
My tweets in the upper door are attentuated. These SatNet X-Overs are really smooth and not bright at all. In fact the 10,000 - 20,000 hz range is low on my RTA.
Most of these guys won't know the difference and will like them up there.
Old May 28, 2004 | 10:11 AM
Hell, I don't even know what you're saying!
