Rear speaker size 2003 F-150 Ext Cab?
Old Feb 25, 2004 | 07:11 PM
Blues001's Avatar
Question Rear speaker size 2003 F-150 Ext Cab?
I want to replace my rear speakers in my 2003 F150 Scab, but crutchfield web site sayd the SPS speakers fit, but the Type R speakers do not fit. They are both 5x7, are the front the rear the same? Is crutchfield wrong?
Alpine SPS-570A 5"x7"/6"x8" 2-way Car Speakers
Aluminum-coated polypropylene woofer • rubber surround • swiveling titanium-coated PEI tweeter • 2-40 watts RMS power range
$109.99
Alpine Type-R SPR-574A 5"x7" 2-way Car Speakers
Aluminum-coated poly woofer • rubber surround • silk dome tweeter swivels for improved imaging • 8-35 watts RMS power range
$199.99
My Truck
Old Feb 25, 2004 | 09:33 PM
cgorris's Avatar
size wise they are the same as far as dimensions but the problem is in the mounting depth. You can pretty much trust crutchfield.
Old Feb 26, 2004 | 10:34 AM
medisconna's Avatar
After replacing my factory rears with Polk db650's - I concur with cgorris. The difference in depth is somewhere between one half to a full inch.
Old Feb 26, 2004 | 01:00 PM
Blues001's Avatar
Ok, great answers thanks, it looks like this...
SPR-574A speaker fits 5"x7"
Top-mount Depth (Inches) 2 3/4
Bottom-mount Depth (Inches) 2 15/16
Alpine SPS-570A fits 5"x7"/6"x8
Top-mount Depth (Inches) 2 7/16
Bottom-mount Depth (Inches) 2 13/16
So, the extra 1/2 inch is the deal killer, is there any room back there at all? Maybe I can shove them in and have speaker grill on the outside of the door panel? No that wont work..... damm...
Old Feb 26, 2004 | 02:06 PM
medisconna's Avatar
At present, the tweeters on the Polk db650's are pushed up against the factory plastic "grill" in my rear doors. Of course, I also have 3/16" of adapter plate material that 5x7's would not require. These speakers have 3/8" tweeter protrusion - thus a total of 9/16" mounted on top of factory speaker cutout. Because these are temporary speakers, I'm not very concerned with the door panel being displaced and it is not causing vibration issues - yet.
If you're going with 5 x 7 replacements, I don't see why you couldn't trim out the door panel "grills" and cover your new speakers with aftermarket grills.
Old Mar 6, 2004 | 02:08 AM
Hazard269's Avatar
Crutchfield has had some mistakes int he past, but they have been fixed by now. If I rember correctly there is enough room to do a spacer so you should be able to fit most speakers back there.
