Help Me Out
Help Me Out
I'm putting 2 10's in my truck. I'm leaning towards the kicker comp vr. Let's say I was going to use a mono amp rated at 600 watts 2 ohm. Would I get the dvc 2ohm or the dvc 4 ohm woofers. And do you wire them in series or parallel. Also Kenwood has an amp KAC-8101D rated at 1000 watts at 1 ohm. What 2 dvc subs (dual 2 or dual 4) do you need to achieve 1 ohm and how do you wire them.
Re: Help Me Out
One more thing in terms of how to power a pair of CompVR10's. They're rated @ 300w each (150w/VC), and trust me, they can take more.
As far as your wiring comments, here's some 'simple' answers assuming a single sub is used. You can apply it further to a multiple sub install as needed.
1 - Wanna run a 2 ohm output load on your amp, buy a DVC sub (4ohm + 4ohm), wire it's two coils in parallel, and you're good to go @ 2ohms.
2 - Wanna run a 1 ohm output load, buy a DVC sub (2ohm + 2ohm), wire it's two coils in parallel, and you're there. Usually, you won't find many cases of people running 1ohm loads unless they're building a competition vehicle, which doesn't sound like what you're doing.
Hope this info helps. Good luck with your sound system upgrade.
-Mike-
Subwoofer Wiring Diagrams
Here's the ultimate page in subwoofer diagrams:
http://www.crutchfieldadvisor.com/S-...rs_wiring.html
It's saved me a bunch of time, trouble and money.
Think It, Plan It, and then Do It!
