I need input on this idea
Right now I have 1 10's in tiny little boxes under the back seat of my extend cab. My lasted idea was going to be screw the seat brackets and just build a box that takes up all the space under the seat and mount the seat on the box. If I do that as is and just build a box for outward facing subs I have no head clearance for people sitting in the back. I think my only opinion is going to be a down fire box. Any ideas??
Are you talking about the boxes that fit under the seat? Those are too expensive for my blood. I'd much rather build my own. Right now I've put a 2x2 under the seat and have small individual boxes that don't give me much room for sound at all. here's a new question.... should I go with a seperated subs or open?
Ok I've played with numbers and I roughly came up with this... air space per sub will be 1487.12 inches. Does that number sound right?? Using 3/4 in MDF my outer measurements are 56x9x12. I'm giving 2 inches ground clearance on the bottom. Does this seem remotely correct? I just wanted to throw somethign out there before I go and take the time to build this.
Re: I need input on this idea
I ran these subs with the same amp in my pathfinder in a downfire box and the amp beat the **** out these subs. The box was a bit smaller. That's pretty much the only difference. I moved everything into the truck. These subs just don't work well with such a small amount of air space.
