Sub wired to 2 negatives?
Old Aug 4, 2003 | 06:03 PM
offroadmaniac's Avatar
I just looked at my wires that are connected from my box to my amp, and they were both wired to negatives. I was like "WTF". So, I put one of them to the bridged positive, and now there is definitely a difference in sound. My bass is so much better now. Would the wiring hooked up like it was, cause my sub to sound weak?
I am so glad i found this, more bass without spending more money.
I'm never letting my friends hook up my wires again.
Old Aug 4, 2003 | 06:24 PM
LightningCrew's Avatar
Not sure how it was working at all being connected to two negatives.
Old Aug 4, 2003 | 06:35 PM
Invalid_access's Avatar
Are you talking about wiring 2 negatives on a two channel amp or they wired them the speaker box on the negative post. What type of subs and amp do you have?
Old Aug 4, 2003 | 08:11 PM
Yea, it was wired to two negatives on a two channel amp.
Alpine E-type 12" sub
Kenwood 600w 2 channel amp.
The weird thing was, after I fixed that. I had it turned up pretty loud, and then it just quit. The amp wasn't working. I thought I blew it or something. Somehow the ground had came loose at where I had it grounded. Fixed it, and it sounded awesome.
Old Aug 4, 2003 | 08:54 PM
If you move the ground a little to much it will come loose on you in a second. I wouldn't push an alpine type e at its peak for very long it might blow. Back the gains down don't run it continously at 600 watts. Is it the dvc model with 4 ohm voice coils.
Old Aug 4, 2003 | 10:06 PM
I'm not sure, how can I tell? The Kenwood isn't pushing 600w, so I'm not afraid of blowing it. I believe when my amp is bridged, it is pushing about 420w or so. At least that is what I was told.
Old Aug 5, 2003 | 12:37 PM
If it is one alpine type e it holds 200 watts rms. You could probably get away with 300 watts to it continuous. I wouldn't push that sub at full power of the amp at all times. Just set the bass to what sounds good and you should be fine.
