mdf thickness
mdf thickness
i am looking at the solo-baric l5 for my center console. At the kicker website it has a reccomended box dimensions, and they are like 1/4 -1/2 inch too tall and maybe a hair too wide for my center console.
But once you get past the opening the console spreads out (1991 xlt lariat) so if i had an extra square attached to the side of the box to restore the airspace lost by slimming down the height of the box, would this work? or does a box have to be relatively square
i was thinking like this
...................top where sub would face up
...........................v
...................______________
side view:......|...................|
.............____|...................|
............|_________________|
not really to scale or anything, but just so you see what im saying
doesnt need to be square. But try this idea... why dont you put a port hole in this part(where the arrow points)
side view:.....|..........................|
.............____|..........................|
...........|__________________|
A perfectly square box is actually the opposite of what you want. A square box can have standing waves inside the enclosure and prevent proper performance of the sub. So adding an extra part to get more airspace is probably a good thing to do.
There is also much more to "porting" a box. You just cant cut a hole and put in a tube. Ported boxes need to be tuned. The proper size diameter of the port as well as the length of the port. Making a sealed box is the easier of the two. Ported boxes will play louder and don't require the amp power that a sealed box does.
