sub box plans
Old May 31, 2003 | 03:05 PM
korte500's Avatar
sub box plans
would like to build a sub box under rear seat with some 10's.
99 f150 ext cab
anyone have any plans/specifications
Old Jun 1, 2003 | 10:46 PM
Invalid_access's Avatar
Subs don't work that way. All subs require different amounts of airspace. It is best just to measure and see what you can get up under the seat. Then figure airspace and pick a sub. That is the best way to get good sound quality.
Old Jun 2, 2003 | 03:59 AM
Hazard269's Avatar
I plan to put two 10w7s under the back seat...Well...I WILL put two 10w7s under the back seat.
I am going to start with the LIMWelding Hi-rider 4" lift kit for the back seat. Then I will fiberglass 3 'sides' of the box (back, top, and bottom), and use 1 inch MDF for the front baffle. In doing this I will end up in the neighborhood of 1.5ft^2 each, which should be a pretty good environment for these two subs. Also, the subs will be firing forward.
