air fuel gauge install
Old Nov 11, 2002 | 03:14 PM
drop-top's Avatar
Has anyone installed an air/fuel ratio gauge? If so, where is the wire and what color is the correct one for the o2 sensor.
Old Nov 11, 2002 | 03:53 PM
HiTechredneck's Avatar
Easy 3 wire hookup. First, do it with battery out of truck (easier to reach PCM)
Hot lead source of your choice, switched - red lead
Second, ENGINE GROUND, not under dash. Negative cable on battery is easy - black lead
Last, red wire with black stripe at the PCM (computer module). It's a B*&^% to find, near the center of the connector - violet lead.
It will bounce all over, but what you are looking for is green when you get on it.
Oh yeah, Solder your connections!
Old Nov 11, 2002 | 04:08 PM
drop-top's Avatar
Thanks man.....you gotta love this board for the info.
Old Oct 6, 2003 | 07:19 PM
scrammer's Avatar
can someone tell me what wire to tap on the O2 sensor? i tapped the black one, and all i get is a constant full green on the a/f gauge. i know thats not right. some help please.. i have a 2K triton v8
Old Oct 13, 2003 | 10:43 AM
1JT's Avatar
1JT
Follow the link for a detailed install
https://www.f150online.com/forums/sh...hreadid=101569
Old Oct 15, 2003 | 11:02 PM
FLOORD U's Avatar
the brown wire
