Sponsored by: DashLynx
2009 f150 ac not blowing
Old 05-20-2019, 04:03 PM
Scburwell's Avatar
My 2009 f150 was blowing heat out one side and cold out of the other. I replaced the door blend actuator, then it stopped blowing all together. I just replaced the blower resistor, which did not work. It still blows cold out of the seats also. Any advice where to start next would be helpful.
Old 05-20-2019, 08:34 PM
Are you sure you didn't forget to plug something in?
Old 05-20-2019, 09:56 PM
Scburwell's Avatar
I was thinking that, I double checked this afternoon and I couldn’t see anything that was unplugged
Old 05-26-2019, 07:23 PM
joe51's Avatar
Did you check the fuses? It sounds like you may have blown one.
Old 05-26-2019, 11:36 PM
Scburwell's Avatar
Update
Turns out it was the blower motor, I replaced it and it’s good to go now. It is odd that it went out at the same time as I was replacing that other part. But thanks for the replies y’all
Old 05-27-2019, 07:30 AM
Mystery solved!
Good job!
Quick Reply: 2009 f150 ac not blowing
