04 expedition 5.4 16v low compression in cylinder 8
Old 02-20-2019, 03:34 PM
Brett95's Avatar
Hello I'm new to this forum. I'm having an issue with an expedition I own. I'm a ford guy but this expedition is changing my mind. I finally took it to a shop after I got done throwing parts at it and they said it has low compression in cylinder 8. Sure I believe that but they quit diagnosing all the issues I wanted looked at after that. It idles rough and runs rough at low rpms and just started knocking. I realize it's needs a motor or a rebuild I can live with that what I'm dying to know is what caused that to happen is it the timing chain or a camshaft issue or could the exhaust be plugged converter or manifold...? Also it did rattle in the driver side towards the back when you gassed it but that stopped
Old 02-20-2019, 05:38 PM
The #8 cylinder needs to be borescoped. Also, pull the valve cover and make sure the cam and followers are okay for that cylinder.
Quick Reply: 04 expedition 5.4 16v low compression in cylinder 8
