plastic spigot broken on radiator drain
Old 11-16-2018, 05:27 PM
chrisd's Avatar
is this replaceable? and how would i do this, hopefully not taking the whole radiator out.
thanks in advance.
Old 11-16-2018, 06:13 PM
What's broken? Pictures would help.
Usually not.
You could take it to a radiator repair shop and see if they can work magic.
Old 11-16-2018, 09:46 PM
MKTRUCK's Avatar
Hopefully the below part is what broke. If its part of the Radiator end/cover, then new radiator.
Dorman sells one for the 5.4l. Maybe it's the same. Try to pick the broken piece out. Ford has them too.
Here's Oreilly's:
https://www.oreillyauto.com/shop/b/c...+Drain+Pet****
MK
Old 11-17-2018, 06:57 AM
jimbo74's Avatar
pics of what is broken?
I broke off my coolant overflow nipple, I drilled and tapped a brass fitting and JB welded in there
Old 11-17-2018, 06:48 PM
chrisd's Avatar
the 19mm plastic head you turn to open the spigot to drain is completely broke off. so can it be tapped to add another 19mm head?
Old 11-17-2018, 08:04 PM
Click on the link in post #4.
Quick Reply: plastic spigot broken on radiator drain
