2013 oem hid lights stay on
Old 08-04-2018, 09:47 AM
off road dude's Avatar
So I just reinstalled hid lights after somebody swapped out junk halogens before I bought the truck. As soon as I plug them in, the low beam turn on. Truck off, on, headlight switch in any position. High beams work fine. I have constant power to the ballasts which I guess is normal. And no power on the low beam circuits unless I move the switch. So I'm kinda scratching my head. I can only get them to turn off if I pull the battery or the fuses. I used osram ballast and bulbs from the retrofit source and spyder housings. Also I thought the led strip in those things was for the drls. My truck is Canadian and drls are the park lamps. Do I need to switch the black and green wire?
Old 06-28-2019, 03:01 PM
OPT7's Avatar
Former Sponsor
Yes. look like you are tapping into the wrong wire. Going to a constant that's probably wired for the DRL. Switch wires.
Old 06-28-2019, 06:17 PM
I think the OP doesn't care anymore.
Old 07-21-2019, 02:21 PM
Haha funny story. That truck got totaled last month. Turned out I was getting water in the connector and cross shorting the low beam to constant 12v circuits.
Quick Reply: 2013 oem hid lights stay on
