2015 F-150 Trailer Disconnect Light
Old 01-19-2018, 09:02 PM
Chris Bonz's Avatar
I have a 2015 3.5 Ecoboost and tow a 20 ft. camper. Since the first day I started towing, the "trailer disconnect " light illuminated on the dash. I stopped and checked the truck and trailer connection which appeared to be appropriately connected.
There is not any repetitive sequence, as it sometimes comes on traveling on flat smooth roads and not on bumpy roads.
Has anyone experienced this when they tow and can offer a solution?
Old 01-19-2018, 09:19 PM
More than likely it is the wiring on your brakes.
I know on my Tekonsha P3, it will show trailer disconnected if I tow a trailer that needs a new wiring job or if the connector is loose.
You might want to check the connector that is on the trailer and the connector on the truck before going further.
Old 01-19-2018, 11:09 PM
Is this with the factory brake controller? If so, did the truck come with it or was it added on later?
Old 01-22-2018, 06:37 PM
Chris Bonz's Avatar
Yes - It has a factory installed integrated brake lever / controller. Others stated it may be a bad connection, however al plugs and pins appear clean.
Old 01-22-2018, 07:07 PM
Have you tried another trailer?
There are trailer dealers and camper dealers that have a tester that can simulate a trailer.
Quick Reply: 2015 F-150 Trailer Disconnect Light
