03 to a 97 engin and transmission swap
Old 09-19-2017, 06:35 PM
William Haddon's Avatar
I have a rolled 2003 f150 it is sound mechanically. And a 97 f150 that runs but has issues I was wondering if it would be possible to make a solid truck between the two and the best way to go about it. Thank you for your time and considerations
Old 09-19-2017, 07:21 PM
What engine and transmission and drive type does each truck have?
(4.2, 4.6, 5.4)
(M5OD, 4R70W, E4OD/4R100)
(2wd, 4wd manual shift, 4wd ESOF)
Old 09-19-2017, 07:32 PM
They both are 5.4 v8 2 wd
Old 09-19-2017, 08:25 PM
And which transmissions do they have - 4R70W, E4OD/4R100?
I'm betting the 97 has a E4OD and the 03 has a 4R70W. The 03 engine is PI, the 97 engine is non-PI. Engine will swap over with possibly some sensor and component location issues, but swapping transmissions will be a lot more involved unless the 97 has a 4R70W. Even then, there are significant differences between a 97 and 03 4R70W. The likelihood of the 03 having a 4R100 is extremely slim.
The PI engine has significantly more power than the non-PI, you may want to get a programmer and custom tunes to take advantage of that.
