Replacing Rotors
The idea behind the drilled and slotted rotors is to unload the gas from the pads during hard braking. With current technology in pad materials, the drilled and slotted for the average driver is no longer needed and can lead to issues, like short pad life and cracked rotors. Unless you just like replacing rotors do not use ceramic pads. They force all of the heat generated into the rotors. You'll have a lot of warped rotors especially if you drive hard. Semi-metallic is best for street use. At one time, the Wagner Thermo-Quiet were the forum favorite for pads.
Typical drilled rotor
I dònt know if I would call that a typical drilled rotor. I've had them before and drove the car very hard and never once had a crack. I have friends that road race and auto cross and have seen plenty that never cracked.
But for the average person it isn't needed. If you feel the need to upgrade slotted will almost always work just fine for the road. They won't do a whole lot for the average daily driver, especially at the cost of a good set.
