I'm helping a friend work on his 1997 4.6 , temp gage doesn't work . Diagrams show two sending / sensor units . It has 2 connectors but only one sensor ? Can read engine temp with code reader , could this be an engine swap or we over looking a sensor ? Thanks
Looked all over , looking at wire it should be only a couple of inch’s away . There’s only one . That and huge scratch under hood makes me think motor has been swapped . I can add to wires if I can find where it is .
The sensor is threaded into the front of the intake manifold coolant crossover on the passenger side across from the thermostat/upper radiator hose connection.
If I unplug this one computer readout goes away , still don’t see a second sensor
