F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   1997 - 2003 F-150 (https://www.f150online.com/forums/1997-2003-f-150-118/)
-   -   Temp sending unit (https://www.f150online.com/forums/1997-2003-f-150/518373-temp-sending-unit.html)
Larryn2o 06-09-2018 05:15 PM
Temp sending unit
I'm helping a friend work on his 1997 4.6 , temp gage doesn't work . Diagrams show two sending / sensor units . It has 2 connectors but only one sensor ? Can read engine temp with code reader , could this be an engine swap or we over looking a sensor ? Thanks
glc 06-09-2018 06:33 PM
I believe there are 2 sensors - one for the gauge and one for the PCM.
Larryn2o 06-10-2018 08:53 AM
Sensor
Looked all over , looking at wire it should be only a couple of inch’s away . There’s only one . That and huge scratch under hood makes me think motor has been swapped . I can add to wires if I can find where it is .
Larryn2o 06-10-2018 05:25 PM
2nd try
took off alternator , no second sensor ? I’m lost
ErikShockey 06-12-2018 06:01 PM
The sensor is threaded into the front of the intake manifold coolant crossover on the passenger side across from the thermostat/upper radiator hose connection.
Larryn2o 06-12-2018 08:20 PM
If I unplug this one computer readout goes away , still don’t see a second sensor
https://cimg4.ibsrv.net/gimg/www.f15...3966673e2b.png
https://cimg5.ibsrv.net/gimg/www.f15...9386ca5c70.png
ErikShockey 06-12-2018 08:34 PM
ErikShockey 06-12-2018 08:39 PM
ErikShockey 06-12-2018 09:28 PM
Okay sorry for the confusion bud. I have a 97 and 99 4.6 and got them confused, both trucks are different.
I fianlly got off my lazy ass and walked over to the 97 and you are correct. Either that truck had an engine swap or the intake manifold replaced.
Here is what it looks like on my 97. The two sensors are side by side
https://cimg3.ibsrv.net/gimg/www.f15...ebcb201ae9.jpg
Larryn2o 06-13-2018 06:28 AM
It’s factory , we have concluded the engine is a transplant, now to find the location of sensor on this one ?
ErikShockey 06-13-2018 06:26 PM
Ford stopped using two sensors in 1999 so you won't find another sensor.
You will need to add the second sensor to the cooling system yourself if you want the gauge to work again.
glc 06-13-2018 11:57 PM
It's also not a coolant temp sensor, it's a cylinder head temp sensor on the 99+.
Larryn2o 06-14-2018 12:46 PM
Found a gauge on amazon that it programable to read out any obd data in real time , thanks
