procharger belt slip
tweeting sounds?? like a bird? can you get a video of this sound
Should I go 1 or 2 heat ranges colder than stock? He is gonna put whatever plugs in there that I tell him to.
No bad miss, or codes coming up so far. It will also be scanned again tomorrow with different scanner tool. All I got is the Xcallibrator 2. I swear it sounds like a tweety bird at idle. You can give it some gas while driving it, and it seems to go away. That could be engine noise drowning it out untill you let off of the gas. Hope to get it figured out tomorrow.
Bravo- Yes. I use Motorcraft AGSF-22C NGK equivalent. It's a stock Tempo piece that fits well. The NGK is the preferred cross reference in a TR6 (8 thread PI only). AWSF-22C is for non PI head with 4 threads.
Sorry double post.
Also dont forget whistles normally indicate vacuum leaks and you can normally hear a rush of air fairly easily if you listen closely. Good ear.
Sorry double post.
check your idler bearings on the timing cover and the tensioner assembly for the procharger. the bearings will make a squeak when they are going out
Will do.
http://www.ebay.com/itm/130197823135...=STRK:MEWAX:IT
if your wanting to upgrade to a low drag high speed bearing for all of your idlers, they would be the ones to go with.
More bad news today. # 2 cylinder is dead. All others were 130 except for that one. I am having it probed on Monday to see whether its a valve or the piston. Either way, the motor will have to be pulled because of the ARP studs. Well there goes another 2 grand out the door.
Sorry about your luck...Look at it this way. You could scrap the procharger, go with a whipple 3.4 with all the goodies, and have a fully built engine! Forged crank, H-beam rods, better pistons, big oil pan, and some built ported and polished heads. Also get the whipple ported, mid-plate, and intake flow matched to the heads and mid-plate. After all that maybe see 700 HP??? Then you would have to build the trans and the rear end... The e-locker out of the 2009+ FX4 9.75's will fit in any 9.75 housing!
Just realized I spilled out my dream build for my truck haha. I am in the middle of a mostly stock lightning supercharger swap on my FX4 screw...
I wish I could afford the wipple, cause I already got the built motor. BTW. I may have got a bad tank of gas. Talked to the guy who is doing the probe, and he has a machine that can test ethenol % in gas. He has sampled as high as 18% in this area. If the piston is bad, that may have don't it. Truck is tuned for 10% not 18.
You can change a head with studs while the engine is in the truck. Put the studs in the back holes and 'tie' them up with a rubber band or tape wrapped around them to keep them just above the deck surface.
