Installed PIE adaptor
Old Mar 5, 2009 | 12:09 AM
tcope's Avatar
Man... what a difference! So much better then using an FM modulator. I am also no longer at the mercy of other FM signals on the same band as the modulator. I was using the modulator to send a signal to my XM radio. The icing on the cake is that I can now plug in an MP3 player to the radio.
The is a seller on ebay that sells them for $65. This also includes your choice of RCA adaptors. Really a good deal.
As with the power and antenna wire, I ran the 3.5mm jack line up under the dash tray and out the side of it. Minimal wires can be seen.
Old Mar 5, 2009 | 05:59 PM
bjp207's Avatar
i couldnt live without mine
Old Apr 2, 2009 | 04:54 PM
illusion03's Avatar
How do you take the radio out to get to it? Does the wood grain cover just pull off? Where is your antenna mounted?
Old Apr 6, 2009 | 01:10 PM
tcope's Avatar
The face panel simply pulls off. Start from the bottom. You then unscrew the radio. Very simple. I have an XM radio in the truck and use the OEM Sirius antenna (just removed the adaptor on the plug in.
Old Apr 13, 2009 | 04:47 AM
illusion03's Avatar
